Doubt to connect several AC-DC outputs
Posted by: pcampos
Dear all.
We have a doubt with one of our design. We have our own opinion but we would like to know yours.
We have the AC/DC design attached. It is a LinkSwitch-TN2 to build a AC/DC converter from three phase (85-265 AC) to 12Vdc@250mA. We use this design in several devices and works fine.
But in a new device/application we are thinking, we neesd to connect several devices output in a chain (attached chain.png). This will connect the 12Vdc output of each converter. VCC_BUS in the schema (There is not Isolation problem)
Do you think this could be a problem? Can we do that?
Thanks to all
Hi pcampos,
The idea seems feasible but we have not tested it yet.
An ORing diode should be added after the pre-load resistor to prevent the output of the converters from interfering with the feedback of each other.
Please see attachment
