DER 832 Transformer
Posted by: Alex Charalampidis
I've been looking into the DER 832 application example and I'd like to find a supplier for the Transformer. Would you be able to suggest one or provide some guidance where I can find one.
Also would it be possible to adjust that application with active rectification on the secondary side to increase efficiency as much as possible?
Thanks in advance,
Alex
hi,
I know a couple of transformer vendors that can help build custom transformer - Bourns and Renco. Please reach out to them if you need help with custom magnetics.
I don't recommend active rectification on the secondary. This is because DER-832 is low power and active rectification will not help significantly.
