TOP232G can be used as HV Buck? (like LNK304)
Posted by: treez on
Would you agree, the TOP232G can be used as a HV buck just like the LNK302?
...for TOP232G, all that would be needed would be to feed a resistance from Vin to the M pin. ..Ans also, to use a bootstrap cap off the Vout liek in LNK302, and connect from this, an R/Zener, back to the control pin....which woudl also be  fed by a 10u via a 10R
Can you see any reason why this wouldn't work?
TOP232G
https://www.power.com/products/topswitch/topswitch-fx/top232gn?langcode=en
LNK302
https://www.power.com/sites/default/files/product-docs/lnk302_304-306.pdf
Would the attached TOP232G schem be workable? What V(out) would it give?
TOP232G Buck 3.pdf (156.5 KB)
Submitted by PI-Wrench on 01/10/2022
It is possible to use TOPSwitch in a buck configuration, though I am unsure of your motivation for doing so. Here is an early treatise on using TOPSwitch in said manner.
https://www.power.com/sites/default/files/forum/files/top%20switch%20Buckconverter.pdf
Keep in mind using TOPSwitch in this way will be a little more problematic than a busk converter employing a device like the Link TN2, as the control pin is used to provide both a control signal and operating power for the TOPSwitch.
