Thermal Shutdown TOP259EN-TOP261EN
Posted by: Tugay on
Hi frends,
I have designed 32V 7A SMPS.I designed using PIExpert. I wrapped the transformer as it was said in PIExpert.Output values are correct, i see 32 volts.
PROBLEM: Top259EN-Top261EN turns off after running for a few seconds. This shutdown is most likely caused by thermal shutdown
QUESTION 1: What should I do for the circuit to work normally without going into thermal shutdown?
I installed a fairly large heatsink but it only increased the runtime by 1-2 minutes. As the load connected to the output increases, the closing time becomes shorter.
QUESTION 2: Vds voltage is 640-650V, sometimes even over 700V. It changes according to the load connected to the output. How can I lower the maximum vds voltage?
I tried making changes to the snubber circuit but top259EN-top261EN exploded. When I checked the circuit after it exploded, I saw that the tvszener diode (P6KE350A) was burned.
QUESTION 3: Is it 640-650V, 700-750V vds_max voltage high for circuit or normaly?
I attached the all needed documents. Real Schematic, Waveforms, Pıexpert project, transformer test results..
In the real schematic design, the values of some components were chosen different from the values that PIExpert said, since we do not have the same value component.
Transformer primary inductance: 250uH
Transformer leakage inductance: 5uH
PIExpert File (1.26 MB)
Vds Waveform1 (285.65 KB)
Vds Waveform2 (252.51 KB)
Submitted by PI-csbabu on 08/28/2021
Hi Tugay,
      I didnt find any attachments added to this post. Please share Pixpert sheet, layout, schematic and transformer details to analyze the problem. All the problems listed above related to transformer design and layout.
Submitted by PI-csbabu on 09/03/2021
Hi Tugay,
       I am able to check all the attached files. The design looks good and this is high power design using flyback, I recommend to check layout carefully. May I know the leakage inductance of built transformer. The higher spike is due to leakage inductance of the transformer and try to reduce high frequency loop area. Please follow layout guidelines in the attached file. If you need further help, please share layout file.
an14_TOpSwitch Tips _Techniques.pdf (358.61 KB) 358.61 KB
Submitted by Tugay on 09/07/2021
Hi PI-csbabu,
Thank you for reply.
Pi expert says that the leakage inductance should be 3.75uh, but I was able to reduce the leakage inductance to between 5 - 7 uH.
The transformer values I am using now are as follows
