INN3370C Not working correctly
Hello PI,
I am using InnoSwitch3 Pro Inn3370C for Power supply design, we are facing different issues like,
1. Facing issues to restart the system again, it's started (there is 5V at VBus) but not going Configured
2. As per the configuration Vout not going to change (Inno3Pro_ramp) it's remains same 5V
3. If configure Vout as 8V, device get restart
It's work at 1st start (configured and take load upto 5A) after that when I try restart it again within a min after Vbus 0V, it's not taking configuration parameter or Q4 not goin to enable but there is voltage 5V at Vbus
No change in voltage after configuration which I set 8v in configuration, it's remains 5v at Inno3Pro_Ramp code which is need to increase linearly as per the code.
Please check schematic design and revert back asap
Rahul
Hello Sky
Please check Attachment for Schematic diagram
Thanks, Rahul
| 첨부 파일 | 파일 크기 |
| DER-625 (131.81 KB) | 131.81 KB |
| RDR-641 (153.41 KB) | 153.41 KB |
| Phynart Schematic (53.32 KB) | 53.32 KB |
Hi Rahul,
The schematic that you attached seems to be good based on the design example reports. I am assuming you're using the InnoSwitch3-Pro arduino library. If so, what kind of arduino are you using? Is the problem only limited to Inno3Pro_ramp or the problems is seen with the other arduino files too?
I would suggest you to try reducing the pull up resistors (R15 & R21) to 2.2k instead of 4.7k if there's any difference.
Could you also tell me anyway that I can send you a new copy of the InnoSwitch3-Pro arduino library just in case that there's a problem with the current library that you have?
PI-Sky
Hello Sky,
Currently i am using this Library for tetsing https://www.power.com/design-support/downloads/innoswitch3-pro-code-library-and-api-arduino
and Arduino Uno Rev3 https://store-usa.arduino.cc/products/arduino-uno-rev3/
I observe that by using ramp code voltage goes up-to 7.75V at no load state Inn3370C is shutdown(No auto-restart), when at constant current 4.5A load Voltage goes up-to 6.5V & Inn3370C is shutdown(No auto-restart) and at constant current 200mA load Voltage goes up-to 7.5V & Inn3370C is shutdown(No auto-restart).
We try all example code from the library to check the circuit performance in which basic code working correctly at 5V/5A but when I change voltage it's not working(Not working with any code & Inn3370C shutdown or Auto-restart)
I am using 5mOhm sense resistor across the IS pin.
Rahul
I mention specifically Ramp code because we observe result on it and trying figure out issues, as per that we observed when voltage or power increases Inn3370C is shutdown.
If there is any Update in Arduino library please share with us, which help us fix the issue.
Email address- rahul.s@phynart.com
Rahul
Hi Rahul,
I've tested the code on our test board with Inn3370C IC. I've seen no issues so far with it. Based on this, I believe that it is not the code that is the problem but some other protection feature is being triggered. Does the shutdown voltage change with input line voltage?
Also, could you check if R14 is indeed 10Ohms 1%?
And lastly, could you help me by using uploading Inno3Pro_Serial. Open serial monitor and setting OV = 10 and afterward CV = 8?
Example Input:
OV
10
CV
8
PI-Sky
Hello Sky,
Ohk, I replace R14 as per your suggestion with this part, https://www.mouser.in/ProductDetail/Bourns/CR0402-FX-10R0GLF?qs=URDPQ%2Fj0cz2NyGyYyiFF9A== But there is no any change in results
i check serial code as per you suggestion 1st i tested with 5V which i shared log and after that i checked 8V configuration i attached log file
also i shared Plotter log for system behavior with and without load please take a look.
Rahul
| 첨부 파일 | 파일 크기 |
| Plotter_With_0.2ALoad.png (3.55 KB) | 3.55 KB |
| Plotter_With_4.5ALoad.png (2.66 KB) | 2.66 KB |
| Plotter_WithoutLoad.png (6.23 KB) | 6.23 KB |
| Serial_Print5V.png (18.67 KB) | 18.67 KB |
| Serial_Print8V.png (18.36 KB) | 18.36 KB |
Hello Sky,
Please cross check Schematic comparison Sheet and Log file we try to read Inn3370 register, we take few reference design and compare my design, as per that we observe few component modification, can you please suggest exact value components.
| 첨부 파일 | 파일 크기 |
| Schematic comparison Sheet (350.51 KB) | 350.51 KB |
| Log file (605.38 KB) | 605.38 KB |
Hi Rahul,
Your primary bias circuit components should be working.
Could you check if the shutdown voltage changes with the Input line voltage?
Also, I did not see the output of the Inno3Pro_Serial.ino that I asked. Could you please check if it is working with Inno3Pro_Serial? Check the output with these commands:
Watchdog
0 (Disable)
OV
20
CV
10
PI-Sky
Hi Rahul,
Could you please attach the schematic and other documents again? It seems that I can't see it here in this thread.
PI-Sky
