INN3268C-H202-TL EMI problems
Good day! We use your INN3268C-H202-TL microcircuit in the power supplies. The problem today is that when a 4kV EMI is supplied with a frequency of 5kHz and 100kHz with different grounding polarities, a short-term decrease in the set value of the output voltage occurs, first to 14V, then to 0V. After removing the interference, the set value of the output voltage is not restored and remains equal to 14V. I attach the oscillogram and the circuit in the attachment. The block parameters are output 24V and 2A. It is worth clarifying that the experiment was carried out at maximum load; at minimum load at the output, this behavior of the block did not manifest itself. EMI tests for 1kV and 2kV units were successful. Thanks.
Hi PI-Chloe!
I do an EMI test for electrical fast transient (EFT)/burst transients.
Thanks!
| Attachment | サイズ |
| Снимок_5.PNG (9.36 KB) | 9.36 KB |
Hi Ensider
Good Day!
Asked if there are reported for this kind of concern. We did not receive this king of concern or experience any when designing INNO3.
I think there is a layout concern that makes the EFT enters the power supply.
The MOV, Xcap, bulk cap should help to prevent the EFT from entering the circuit.
I also observed that there is a lot of Ycap, I'm thinking that it can be a possible path of the EFT depending on the PCB layout.
Patrick
Hi Ensider,
Good day!
I would like to know the specific EMI test that your doing.
Patrick
