DPA424 input power rise
Posted by: SV on
I used the DPA424 to make a flyback converter.
The input will be a PoE voltage and at the output i should have -18, +18, 50, 7 and 3v3.
At start-up all works normal but after a short time the input power starts rising slowly at half the maximum load.
At full-load, the input power starts rising much faster.
Should i check the feedback circuitry? Or is the fault somewhere else?
Thanks in advance!
Submitted by PI-YY on 01/26/2021
Hello SV,
Thank you for using Power Integrations product.
It seems that something is wrong with more consumption in the circuit.
Can you monitor the output voltage and the feedback circuitry to see if anything is changing with the input power. we can start the debug from there.
best Regards
Submitted by SV on 01/27/2021
In the attached file, some scope pictures can be found.
Regarding the output power and feedback signal, these are constant over time.
Another thing to note is that the rise in input power is exponential.
I also noticed that when i powered the device for some time and let the input power rise, next i put it off for some time and thereafter i put it back on, the input power rises more quickly then when i leave it off longer. (So maybe something temperature related?)
Submitted by PI-YY on 02/03/2021
Hello SV,
All the waveform looks normal. Is this waveform capture during the normal operation or after the power rise?
If this waveform is captured during the normal operation, please also try to capture the same waveform during power rise.
If this waveform is captured during or after power rise, this means the 3.3V channel and the feedback loop is normal. there is something wrong with other outputs, you might want to compare the similar waveform for other output windings to see which has significant change during the power rise.
Best Regards
Submitted by SV on 02/16/2021
I measured all outputs during the power rise, but didn't notice any significant changes.
The device can now deliver up to 4.5W without any problems, but higher powers give problems.
Could this be the behaviour when the transformer goes into satturation? Is there a way to test this?
In attachement you can find the datasheet of the transformer.
We asked for a transformer with a satturation current of 400mA.
datasheet transfo (438.27 KB) 438.27 KB
