DER-507 and triac triggering
Posted by: Michele Mocellin on
I'm using DER-507 design to power an MCU (ATtiny 402), and I'm using this MCU to trigger a logic level triac (BTA137 600E).
When I set the MCU's pin connected to the gate in HIGH state the triac go into conduction state, but when I set it on LOW state the triac go into a "semi conduction state". I also tried to connect the gate directly on power supply VSS but the result didn't change.
What I'm doing wrong ?
Submitted by PI-Hiro on 12/10/2021
Hello Michele Mocellin,
Can you send the schematic and PIexpert computation so that we can understand the issue?
PI-Hiro
