connecting two LNK3206 in parallel
Posted by: oferzv on
Is it passable to connect two LNK3206 in parallel to gain more current?
Submitted by PI-Salt on 07/30/2021
Hi oferzv,
Thank you for showing interest in Power Integrations and its products.
Parallel usage of the product is not done in order to gain more current. It is advisable to use higher size equivalent of the same family, in this case LinkSwitch-TN2 that can provide you higher current limit for your specific application.
To guide you: LNK3206 has max current limit of 650 mA using the standard current limit (Cbp=0.1 uF) based on the datasheet given below (p. 12):
https://www.power.com/design-support/data-sheets/linkswitch-tn2-data-sheet
Choosing a higher size such as LNK3207 can give you max current limit of 1137 mA using the standard current limit (Cbp=0.1uF).
You can also use the PIExpert tool in this website to aid you in the design. I hope this helps!
Thank you and please let me know if on how I can be more of help.
Best regards,
PI-Salt
