Can`t find solution PSU 180-430VAC input, Output 12V5W
Posted by: EdwardT
Please help me with design of fully isolated scheme with HighLine.
Normal input is 230, but necessary save efficiency when two power lines will be 230V (√3*230=397V).
I want find solution on power supply with characteristics 180-430VAC input, Output 12V5W
Your design recommendations mostly 300VAC maximum
230+230=400V PSU
(141.3 KB)
Hi Edward,
Thank you for your interest in our products.
May I ask the intended application of this design? I can point you to some designs that are somewhat close to your desired input specifications.
Please have a look at this design for reference:
You can also take a look at designs under "Meters and Industrial Equipment" or "Appliances and Unstable Mains".
