Can a step-down converter do the step-up in reverse?
Posted by: ROSELJR on
Can a step-down transformer do the step-up in reverse? For example, a transformer inputs 220V and outputs 12V. Because the turns ratio of the primary coil and the secondary coil is equal to the voltage ratio, if I add AC 12V to its secondary coil, can it output 220V on the primary coil?
Submitted by PI-Jodec on 11/12/2021
Hi ROSELJR,
If the transformer mentioned is a forward transformer then it is possible. Thanks!
PI Jodec
