Battery charger 12V 5A(min)
Posted by: cth000182 on
Any reference designs for a 2 stage (or more) 12V, 5A (minimum) battery charger? i.e. CC (or constant power) to set voltage, then CV
I found a few within the resources, but wanted to reach out if anyone else had any luck? Also, any dev kits for such an application?
Thanks in advance!
Submitted by PI-Tarmo on 11/19/2021
Hi cth000182
Thanks for considering using Power Integrations Product.
We have a reference design for battery charger which uses HiperLCS and LinkSwitch.
https://www.power.com/design-support/design-examples/der-850-240-w-llc-cvcc-battery-charger-power-supply-using-hiperlcs-and-linkswitch-tn
Also, may I inquire what are your charging specifications? Why do you need a 2 stage for a 60W battery charger?
I can recommend to look at InnoSwitch3 CP product to use on your project.
