About the difference in frequency between INN3168 and INN3270
Posted by: 吹田敦
I’m considering replacing INN3168C-H107 with INN3270C-H217.
When only the ICs were replaced on the same board, the INN3270 was operating at a lower frequency than the INN3168 even under the same input / output conditions.
What is the origin of this difference?
Hi 吹田敦,
INN3270 has higher Ilim vs INN3168.
Ilim (primary current limit, as shown in the datasheet).
Jedidiah
