TOP271EG CVCC SMPS 15.3V / 10A ISSUE
Posted by: sksahoozzz on
Sir, I have made a CVCC SMPS as per the circuit design by PI Expert Suite.
My requirement is CVCC 15.3V / 10A (153W)
The SMPS delivers 15.3V but 1.5A only.
Please help me how to gain Ampere to 10 ?
CVCC_3_1.pdf (180.11 KB)
Submitted by PI-Wrench on 02/24/2020
Try checking your transformer primary inductance and output winding polarity. The transformer core must have an air gap in order to store the proper amount of energy per cycle without saturating. Also, the windings must be configured such that the anode of D3 goes negative when the primary switching fet in U2 is on.
The circuit as shown is only capable of CV output. Additional circuitry will be needed for CVCC functionality.
Submitted by sksahoozzz on 02/25/2020
Sir, I have getting 9Amp now by replacing C4 which was faulty. It is working fine with Resistive load like DC BULB.
But when connected to battery it restarts / no charging.
The Transformer data is in attachment.
Should you guide me the additional circuit for 15.3V / 10A CVCC SMPS (Purpose Lead Acid Battery Charging)
CVCC_3_5.pdf (330.58 KB) 330.58 KB
Submitted by sksahoozzz on 02/26/2020
Sir, Can I change my circuit to CC mode with some minor modifications. It will be ok for me without CV mode
Submitted by PI-Wrench on 02/26/2020
You will need CV mode as well so that the power supply does not lose its mind when unloaded.
