Modeling TL-431 in AN-57
Posted by: h.hasebe on
I tried to make transfer function for output circuit (Fig 23) in AN-57. However I cannot get Equation 23. Would you advise how to get it? BR
Submitted by PI-csbabu on 07/23/2020
I still checking with author for reference material . I will come back to you.
Submitted by h.hasebe on 08/03/2020
Hi, if you can update, it is really appreciated.
Submitted by PI-csbabu on 08/04/2020
Please check attached material to derive the equation. This equation is slightly different from the one given in application notes. The attached material gives the correct equation.
Design_with_TL431.pdf (4.65 MB) 4.65 MB
Submitted by h.hasebe on 08/08/2020
Thank you for your reply. Vfb/Vout is provided on equation 3-58 on the PDF you sent. I can consider equation 3-58 to get equation 23 on AN-57. However there is one problem. On equation 23 on AN-57, there is KTL431. Would you advise how to remind KTL431 to get equation 23 from equation 3-58? Best Regards
Submitted by PI-csbabu on 08/10/2020
Hi ,
Please ignore the equation given in application note and follow the procedure given in previous attached document.
Submitted by h.hasebe on 08/10/2020
Thank you for your reply. Do you mean that equation 23 in AN-57 is NOT correct? If it is NOT correct, would you revise AN-57?
Submitted by PI-csbabu on 08/11/2020
We are discussing internally, will update once finalized.
Submitted by h.hasebe on 08/27/2020
Thank you for your reply. Do you mean that the link "https://greenductors.com/" is your reply? I do not understand the meaning of the link. If you can explain the details, it is really appreciated. BR
Submitted by PI-csbabu on 09/07/2020
Hi Hasebe,
It was a spam message posted by someone. Sorry for inconvenience.
