ISOLATED SWITCHING POWER SUPPLY
Posted by: telles_cps on
Hi guys, I´m new in projects with Switching Power Supplies. I was read the EPR32.pdf and I find a decive to assembly.
This project contais a output with -24v/50mA
How I can swap the voltage to positive and impruve the Iout to 1A?
Thanks to all!!
epr32.pdf (2.09 MB)
Submitted by PI-csbabu on 04/28/2020
Welcome to power supply design. Do you need single output or multi output ? The application note has multiple outputs and total output power is around 25W peak. Please let me know the design requirements like input voltage range, total power & output voltage, so that I can suggest you best suitable part.
Submitted by telles_cps on 04/28/2020
Hi, PI-csbabu!
I need multiples outputs. My ideia its made a power supply with 3v3, 5v and 24v (CC), each with 300mA.
Input 110-220 AC.
TKS!
Submitted by PI-csbabu on 04/30/2020
I recommend to you latest INNOSwitch series to reduce number of components instead of TOPswitch. In terms of design, use additional 6T stack winding on W5 &W6 to get +24V. Since 24V output delivering more power, close feedback loop on that. Remove w7 and w8. Please use PIexpert tool available online for preliminary design analysis.
