Active Battery Balancer
Posted by: Dave Cook on
We are investigating an active battery balance system move up to 2 amps in and out of 12 volt batteries connected togther in in a 648 volt series string of batteries. There is a common 72 volt battery system that can be used as a buffer.
The question is if there is an isolated PI switch topology that could be used to move these 2 amps in either direction or should each 12 battery have both an isolated buck and isolated boost circuit to move the 2 amps into and out of the 72 volt buffer battery.
Dave
Submitted by Dave Cook on 08/18/2020
Just following up, if no one responds here, how do you get engineering support to answer simple questions like this?
Submitted by Dave Cook on 08/24/2020
Still trying to figure out how to get through to an application engineer to discuss options for the simple request below.
Submitted by PI-YY on 08/24/2020
Hello Dave,
Thank you for interested in using PI products.
Do you have a block diagram about how the 12V battery, 648V battery and 72V buffer connected? And how much is the power are you trying to converter here.
Best Regards
