Undervoltage/Overvoltage Protection
Posted by: zahra on
In topswitch Hx family datasheet is suggested to connect 4M ohm resistor to V pin for Undervoltage/Overvoltage protection, But why PI expert put two 4.64 M in series, in this case due to undervoltage threshold current is 25 uA and overvoltage threshold current is 112uA so undervoltage is programmed to (4.64+4.64) *25=232V and overvoltage to (4.64+4.64) *112=1039V.
I attached the schematic
Best Regards
Submitted by PI-Wrench on 10/10/2019
I will be passing this question to the people who oversee the PI Expert software. In the meantime, please go ahead and calculate your UV/OV resistor value based on the threshold currents from the data sheet.
Submitted by zahra on 10/15/2019
Thanks a lot
I would be grateful if some one answer my question.
Best Regards
Submitted by PI-Wrench on 10/15/2019
As I said, I have passed your question on to the people in charge of the actual code for PI Expert - they will need to have a look.
Submitted by zahra on 10/16/2019
Thank you kindly
Submitted by PI-Kenobi on 10/27/2019
Does your design require UV, OV or both? In your example, you have enabled UV and disabled OV, which is why the two 4.64M resistors are used on the V-pin.
Go to the design tree on the left of your PI Expert design and select PI Device -> UV/OV and make the appropriate selection.
Submitted by zahra on 11/02/2019
Thank you for your help.
I think the circuit that PI expert suggests for both UV and OV is different from the topswitch HX datasheet.
I attached 2 photos about PI expert and datasheet. Please take a look at them.
Best Regards
Submitted by PI-Kenobi on 11/26/2019
The two circuit implementations you have attached are exactly the same. The only difference is RLS1 = 9.31 M for the high line design - which makes sense.
Submitted by zahra on 04/08/2020
