TOP258PN - 10W power supply design
Posted by: monil9
Dear sir,
I am designing following power supply
IP dc voltage - 100 to 400V
Single Op Voltage - 350Vdc @30mA
Please find attached my circuit diagram & transformer details.
Problem :
My power supply not starting, it will on and off continuously.
Thank you for your reply,
Yes, it is not staring at any load condition including no load.
I observed the waveform of C49 and it is sawtooth, not smooth dc. I have increased turn ratio of Aux winding but still not starting power supply.
I request you to give all design of 350VDC 30mA including transformer.
so I can complete my project earlier.
I am designing this power supply for an industrial printer.
Do you find that the startup problem occurs at all load conditions including no-load? Monitoring the voltage across C49 can help identify if at least the supply voltage is up before AR event
PI-Kryten
