TOP258PN - 10W power supply design
Posted by: monil9 on
Dear sir,
I am designing a new power supply with TOP258PN
IP voltage range - 100VDC to 450Vdc
Op : 350Vdc @30mA
Transformer Details :
Primary - L 1050mH - 30Turns - 26SWG
Secondary - L 10mH - 100Turns - 25SWG
Aux 1Turns
Please find an attched schematic diagram.
Problem: Power supply not working continuously. it works on and off continuously.
Submitted by PI-Kobe on 07/12/2019
Good day!
Do you have drain voltage, current waveforms of the power supply during this state? Can you say how long(in seconds) the power supply turns on/off continuously? Thanks.
Submitted by monil9 on 07/15/2019
yes, sir, the waveform is like a sawtooth.
approx 2-3hz.
I request you to give me all the designs for 350Vdc 30mA including transformer.
designing it for INDUSTRIAL PRINTER POWER SUPPLY
Submitted by PI-Kobe on 07/19/2019
Hi!
Could you attach the sawtooth waveforms that you mentioned? Did you design the schematic using PI Expert/PI XLS? If so, may I see the spreadsheet/reference design from PI Expert?
