Quote# QADE70E - Usage of LNK304DG at lower currents
Posted by: Adnan on
***** Quote# QADE70E *****
can you please advise on the following question of one of our customer's regarding the DC/DC converter P/N: LNK304DG ?
I like to use the device in buck configuration with a DC voltage source.
It's not a typical application, but my question is if it's working with for example lower output current.
Is it possible to use the LNK304 with input voltages below 70V?
My required input voltage range is 60-167VDC, output voltage 12V, output current 100mA...
Thank you very much.
Best regards
Adnan
Submitted by Adnan on 09/17/2019
our customer returned with the following question. Can you please advise on this?:
PN: LNK304DG: What are the limitations when using 50V input voltage?
Is there a limit of the max. output current? Or why is it mentioned to be >= 70V on Key Application Considerations on page5?
Best regards
Adnan
Submitted by Adnan on 09/30/2019
Can you please advise on our customer's follow-up question below?:
Best regards
Adnan
Best regards
Adnan
Submitted by PI-Jango on 10/01/2019
Because LNK-TN family of devices is primarily used for buck converters, the output current will always be limited by the peak current limit of the IC, as shown in Table 1.
LNK-TN operates at 66khz only (with on-off control) and fixed peak limit, so you can expect the max power delivery to be limited at very low input voltages. Although the IC will operate down to 50V (meaning switching will still occur), it is optimized to be used within typical AC input ranges.
