Isolated flyback AC -DC converter with power factor correction
Posted by: Bhargavkrishna on
I am trying to design an Isolated Flyback AC-DC converter, with output power around 20W. One of the main requirements of this design is a good power factor (>0.9).
What would be the best choice of flyback controller from power integration to do this job.
I have seen LNK6766 series controllers, does this have the PFC option.
Please suggest
Bhargav
Submitted by PI-csbabu on 10/25/2019
Thank you for your interest in PI products. I would like to know below information.
What is the input voltage range ?
Output voltage and no of outputs?
What is the input voltage and load at >0.9 PF?
What is the end application?
Submitted by Bhargavkrishna on 10/28/2019
Input range : 90 - 200VAC
output : single output,17.2 V, 1.2A
need to achieve a PF >0.9 at 115V assuming full load.
end application is lighting.
Please let me know if you need any further information/clarification.
Bhargav
Submitted by Bhargavkrishna on 10/29/2019
Is this only restricted to LED applications? or it can be used as a power supply in general.
in our case the load will be LEDs but just to understand your suggestion more clearly.
Thank you!
Submitted by PI-csbabu on 10/30/2019
Hi Bhargav,
It can operate in CC mode only and no CV operation. So you cant use as a general power supply.
csbabu
Submitted by Bhargavkrishna on 10/30/2019
is there any controller which operates in isolated flyback topology, achieves PF>0.9 and fits in the requirements that I have mentioned earlier, irrespective of the end load?
in short that should be more like a power supply rather than end load dependent solution.
Thank you very much!
Submitted by PI-csbabu on 10/31/2019
Hi Bhargav,
We don't have controller offering >0.9 p.f independent of end application.
csbabu
