current limite
We are an Algerian company (Centrelec) we need some technical information about your products topswitch GX/HX, we need a document that explain how to limite the current because in your documents i don't find how to limite current of your product.
Cordialy.
Hi hicham boutouche,
You can access the TOPSwitch-GX datasheet on this link: https://ac-dc.powerint.cn/products/product-archive/topswitch-gx/
To answer your question about the current limit, on page 7 of the datasheet you can adjust the current limit by an external resistor between Pin (X)/(M) depending on the package and Pin (SOURCE).
PI-PIke
hi PI-PIke
Thanks for the documents if i understood I can limite the current with external resistor and there is a graph to select the value of the resistor,but if I want to limit the power how I chose the value of second the resistor between the x pin and the dc line
regards,
You can check AN-29 & AN-32 Design Methodology on how you can trim the resistor on your desired current limit value.
PI-Pike
i search evry where but i don't find a document who explain step by step how to limite the current
