TNY 289 OUTPUTS FLUCTUATIONS AND OUTPUT DROPS WHEN I DRAW THE CURRENT
Posted by: Tarun
Hi PI Team,
Here I have designed a SMPS for the output of +18 and -18V with a current rating of 0.5A.
The output of the +18V varies from +22V to +25V and where as negetive output remains +25V stable.
When I connect the Load to the output the output suddenly goes to zero and keep variying.
Kindly suggest the solution. Here I have attached the schematic
18 - 0 - 18 /0.5A
(2.85 MB)
Hi PI team
This schematic & transformer is designed using PI Expert suite.
Kindly tell me what are the corrections to be made in the schematic to make it work.
Hi Tarun,
Let's try changing the regulator circuit. Attached here is the schematic for TL431 for the modified secondary circuit.
Jedidiah
| Attachment | サイズ |
| 18V_-18V_dual_output.png (51.87 KB) | 51.87 KB |
Hi Tarun,
You're schematic won't run. One of your output is in flyback condition while the other is in forward.
Jedidiah
