A schematic of the power supply with fast start
Please help me to design of the power supply with following features:
- power 8...10W
- input voltage 120...250 VAC 50/60 Hz
- output voltage 15...18V
- setup time: < 50 ms
- hold-up time: > 500ms
If it possible I'd like to have a non-isolated schematic.
I would be grateful for any help in creating
hi, Im looking for a design for 3 Phase 6KV Surge Protection Isolated PSU, 10W/12W Output,
3 Phase input
6KV Surge protection
EMI/EMC compatability
Isolated
Output 5/12V 10W Max.
Above 85% efficiency
All other protections.
please suggest the Solution.
We have several design examples on our website and I am providing a link below for your reference. You can sort these designs based on operating voltage range to find a design that meets your requirements best:
https://ac-dc.power.com/design-support/reference-designs/design-examples/
If you have a specific questions related to use of one of our products or its feature or a performance issue with one of your designs, I can help answer.
If you need support however with putting together a complete design, you will likely need a consultant or FAE to support.
Please contact one of our distributors who may able to assist you. I am providing a link below for your reference:
https://ac-dc.power.com/sales/distributors/
I hope you find this information useful.
Sincerely
Need assistance to determine if PI has a suitable component / solution
Embedded microcontroller application for industrial process; 125dgC
Vin (max)=250Vdc with ripple derived from 3 phase 60Hz, full wave rectifier; Ramps up from 0 to max in 1-2 seconds.
5Vdc output when Vin exceeds 20Vdc. Could also be a higher DC output and run through a secondary regulator to get 5.0Vdc.
Output current 20mA, to supply micro and associated I/O.
Output should be isolated.
Need fast turn-on when Vin exceeds 20Vdc; within 40mSec.
Kindly check the following link for a product that best suits your needs:
PI-Kryten
Thank you for considering Power Integrations for your power supply application.
Can you kindly let us know the intended application of the product?
There is a wide range of product families that you can choose from depending on the application.
Once an IC family has been chosen, please refer to the design example reports (DER) available for that particular IC. These will help you design your intended power supply.
Hope this helps.
PI-Kryten
