Looking for replacement of TOP223P in non isolated buck converter
Posted by: d.schouten on
Hi all,
For some years we are using the TOP223P in a non isolated DC-DC buck converter design. The output power is only 3 - 5W, the input voltage range is 30 - 200Vdc and the output voltage is tuned to around 20Vdc. This design is based on PI's first Design Idea (DI-1, as attached to this message).
The TOP223P currently has a NRND status, so we are considering to redesign the board a little bit and implement a newer PI part. My question is, which newer PI part(s) are the best replacements in this application?
Thanks in advance for your feedback!
Dan
Submitted by d.schouten on 10/17/2018
Hi Kryten,
Thanks for sharing an alternative for the TOP223P.
Do you think the JX series can also be used in a non isolated buck dc-dc configuration, similar the earlier attached design note?
Thanks in advance!
Submitted by PI-Kryten on 10/18/2018
Yes you can
PI-Kryten
Submitted by d.schouten on 10/18/2018
Great. Thanks!
