InnoSwitch-EP INN2904K. How to increase and decrease the output current.
Posted by: wkrommer on
I want to change from 12V/1,25A and 5V/0,5A to 12V/0,6A and 5V/2A?
Thanks in advance.
Submitted by PI-Sarek on 07/18/2018
We provide a tool called PIExpert which helps with design of power supplies using our products. This tool is offered free of charge. Please use the link below for additional information about the tool:
https://ac-dc.power.com/design-support/pi-expert/
Page.20 of the report that you are referring to shows how the tool is used for creating the design.
I hope you find this information useful. Please refer to the applications section of the datasheet for the part that you wish to use. The applications section contains information and tips regarding selection of components and circuit board layout.
Submitted by wkrommer on 07/18/2018
Thank you very much for the help.
But in PI Expert I can find the InnoSwitch3-EP only. The InnoSwitch-EP (INN2904) is not available.
The INN2904 is available in PIXs Designer. But the schematics function is not enabled.
What can I do?
Thank you in advance.
Submitted by PI-Sarek on 07/19/2018
That is correct. While all our products have a PIXls spreadsheet only a few have PIExpert support.
In this case you would need to use PIXls for designing the transformer and the datasheet applications section for guidance on completing your design.
