AC/DC for 230VAC/50Hz as well as 115/60Hz input and multiple output for 24V, 5V and 3.3V
Posted by: abhilashs@expe…
Please suggest the design for following requirement :
IInput : for both 230VAC, -15% to 10% and 115/60Hz
Output : 24V @1A (24W), 5V @500mA (2.5W), 3.3V@500mA (1.65W)
Thank you,
Detail requirement are as below:
Hi abhilashs,
I encourage you to use our PI Expert Online tool. It is designed especially to help our customers to get up and running with a design based on their specifications. If you have issues using the tool, please feel free to post a comment in the PI Expert Technical Forum.
-PI-ODO
Hi abhilashs,
Please re-post (including the output current requirements as well) in the appropriate technical form. For <100W, please post in the Low Power forum. Also, you can use our PI Expert Online tool to create a design based on your specifications.
-PI-ODO
