800VDC input flyback supply
Posted by: cjf3rd on
Does Power Intg have any parts that can be used to create an ~5W flyback power supply from 400 to 800VDC input?
Submitted by Easy Peasy on 02/08/2018
An half bridge is probably the safer approach here...
Submitted by Easy Peasy on 02/15/2018
At 800V in + 130V flyback you will need 600V from the PI part + a 600V fet say giving 1200V of capability with a stackfet configuration, to handle 930v at turn off.
The output diode will see Vo + 800V x turns ratio... thus a higher flyback voltage is beneficial here ...
Submitted by PI-Mallora on 08/13/2018
Hi Karmen,
On the DER-58 report, there is transformer spreadsheet section on page 12. Just follow those inputs. You will have warnings on Vdrain voltage stress but just disregard it since it is using stacket. Thank you.
Submitted by Karmen Cox on 08/14/2018
We tried the transformer spreadsheet section on page 12 of DER-58. Didn't work at higher voltages. Transformer manufacture suggested using a larger transformer described in DI-124. Also used PIXIs designer that leads to a different larger transformer. DER-58 only shows low voltage wave shapes pages 15-19. Do you have a support structure for StackFET? Is PIXIs designer the best tool for designing a transformer for a 580VAC StackFET design?
Submitted by PI-Mallora on 08/21/2018
Sorry I figured out that you needs 800Vdc max input so INN2904K won't be enough for your requirement.
