72VDC 5Amp Power Supply for Battery Charging
Posted by: Ishan on
We have to design 72VDC, 5Amp power supply for battery charging purpose.
It doesn't matter if its isolated or non isolated, no PFC required.
I have referred the DER-547 application note for HiperPFS-4 but unable to get idea about how to set the output voltage.
It would be great if someone can help me out with this.
Submitted by Ishan on 10/21/2018
Hi PI-ODO,
Thanks for the response..!!!
I am more interested in DER-547 which is a transformer less design and utilizes Hiper-PFS4.
I guess I can change the feedback resistor network to change the output to 72VDC.
But you are suggesting DER-472, so is that the case where DER-547 [Hiper-PFS4] is a PFC Front End and cannot be used a power supply ?
Ishan
Submitted by PI-ODO on 10/23/2018
Hi Ishan,
You are welcome! As you noted, DER-547 is intended as a PFC Front End (100 VAC – 300 VAC Input; 440 VDC Output) and works as a *boost* converter to provide a high-voltage DC bus. Typically, a subsequent power supply stage is then used to generate the desired lower voltages.
-PI-ODO
Submitted by Ishan on 12/07/2018
Hello PI,
I have started looking at the reference design suggested by you. The input voltage range is 90-132 VAC but I need universal input range of 86-265 VAC. I see that mov RV1, cap C3 and C4 limit the input range, please let me know if there is any other component that needs attention.
One more point is that I need 72VDC 5Amp (Main Output) and 12V 1/2Amp (Standby Output).
But I am unable to find the output voltage equation in the HiperTFS2 datasheet.
Request you to provide your inputs on above points.
Thanks..!!!
Submitted by PI-NANO on 12/11/2018
Hi Ishan,
Here is the design with universal input voltage range.
https://ac-dc.power.com/design-support/reference-designs/design-examples/der-484-300-w-forward-power-supply/
https://ac-dc.power.com/sites/default/files/PDFFiles/der484.pdf
Standby output is a separate fly-back converter, so it is independent operation from main converter.
Please use PIxls spreadsheet to design your transformers
https://ac-dc.power.com/design-support/pi-expert/pi-expert-online/
PI-NANO
Submitted by Ishan on 12/13/2018
Hello PI,
Thanks for the update..!!!
What if I don't need PFC stage of HiperPFS-3 ?
Can I directly input 86-265 VAC at the B+ and B- terminals in the second stage comprising HiperTFS-2 ?
Please let me know.
Thanks..!!!
Submitted by PI-NANO on 12/13/2018
Hi Ishan,
No you can connect the AC input directly on B+ and B-.
PI-NANO
