RE: INNOSWITCH SMPS DESIGN REVIEW
We are currently designing a 230V to 3.3V SMPS we converting 230VAC to 5VDC using the innoSwitch INN2023 and then converting this voltage to 3.3V using a linear Voltage regulator.
We are presently considering RDR420 for design and the PCB designed alligns to it(mostly).
We kindly request you to review the PCB design for the same before We give it production.
Please Note:
1. The source Pin is not correctly heatsinked(just the PAD) I will rectify.
2. I will also rectify the stiching vias
Please find the attached CADSOFT Eagle files
Thanks and regards.
Siddharth
Sorry for the delayed response.
Please find attached the TOP and the BOTTOM layer for PS mentioned above.
Kindly review at the earliest.
thanks and regards
Siddharth
| 첨부 파일 | 파일 크기 |
| Power supply TOP (33.16 KB) | 33.16 KB |
| Power supply BOTTOM (43.72 KB) | 43.72 KB |
Can someone please review the Pcb layout for the innoswitch
This is a bit urgent
Thanks and regards
Siddharth
Hi Siddharth,
The images you sent have both sides (top and bottom side) reference designators and footprints still visible so I am finding it difficult to interpret as many reference designators are not clearly visible or some are missing and so I have to guess and trace the component.
In the layout:
I don't see the FB connection to R7 which is the lower feedback resistor.
I don't see C11 connected to Vo.
I am guessing the locations of U$7 and U$4 as these names are not visible in the layout.
I don't see U$6.
I don't see a spark gap for ESD or surge protection.
Please make sure you also have the minimum creepage and clearance distance from primary to secondary if your transformer core is not covered with any insulating tape.
PI-AP
Hi PI-AP,
Thank you for your comments. I am sorry for the lack of visibility of the components. I am unable to attach the EAGLE files here.
I have incorporated all the changes mentioned
There was a problem in the NET. I have rectified it
It is connected via TOP layer
I have incorporated the names in the LAYOUT attached
I don't see U$6.
This is the Y cap, I have included the name in the layout attached
I don't see a spark gap for ESD or surge protection. I haave included this but is these a necessity? I have not seen this in one of the RDRs but have included a 1.5 mm width spark gap. Please refer the Layout attached
I am Using POL-INN05 from Primer Magnetics
http://www.premiermag.com/pdf/pol-inn005.pdf
Anything else I need to to do?
Thanks and regards.
Siddharth
| 첨부 파일 | 파일 크기 |
| TOP layer (33.62 KB) | 33.62 KB |
| BOTTOM Layer (44.21 KB) | 44.21 KB |
| Schematic (20.03 KB) | 20.03 KB |
Usually the ESD spark gaps are 6.4 mm or 6.8 mm. The primary high voltage side to the secondary side creepage distance needs to be 8 mm or more if the transformer core is treated as primary and not covered with tape. These are recommended for safety, to make the ESD and sruge tests pass. RDR420 does follow these practices.
I will surely rectify the spark gap distance.
The creepage is more than 8 mm. I have verified and would like you to have a glance
According to the datasheet the creepage distance has absolutely fine.
One more thing I want to confirm I am using track width of 24mil. I have taken into account 2A as maximum current and selected the track width(all though the current would never reach 2A)
Siddharth
Just wanted to confirm what are you referring to exactly by track width? Are you referring to the trace width?
PI-AP
Yes I am referring to trace width??? Is that OK??
Siddharth
Hi siddharthtaunk
I also try to start design a USB charger using INN2023.
But I can't find Eagle library.
Could you send me a link to this or did you do a library by yourself ?
Or if it's not a secret project can you send me sch and brd file ?
Thanks in advanced.
Could you please send images of top and bottom sides separately so that it is clearer to understand?
PI-AP
