Power supply for HiperPFS
Posted by: thrmack on
How can I create a power supply for HiperPFS (VCC) ? Is it ok to use the LinkSwitch-TN in buck mode, from the input, for this power supply design?
Thiago
Submitted by PI-Neela on 01/20/2017
yes you can. as far as the pri and seconary isolation is achieve. PFS Vcc supply is from the bias circuit. PFC Vcc is consider primary.
Submitted by PI-Neela on 01/26/2017
sure you can. as far as they both are on primary side.
Submitted by thrmack on 01/26/2017
Ah, I see. So that should be fine, since I´m gonna use a non isolated buck converter (LED driver) at the PFC output, so no transformers in the circuit.
