looking for a solution for 9 - 250VAC in, 6VDC out @ 2A
this would be my 3rd time posting this question in the last 3 weeks. it does not need to be an isolated solution. the 9 is not a typo.
Hi Jon,
Hope you're doing well and Thanks for choosing Power Integrations. We are now looking for a solutions for your power supply design specifications and we will get back to you once we figure it out . By the way may I ask what applications are you gonna use this power supply and how much efficiency is required.
Thank You
Martok
I am interested in a similar solution. DC 20-150V to 3v3 for low cost solution. Current ~500mA max.
Was tehere any positive outcome on this question?
Hi Jjongerius,
Thanks for your interest in Power Integration Products. I have reviewed your power supply input requirement and my suggested solution is to use buck converter topology. However we don't have device that can meet your minimum input voltage requirement. Our smps controller products are mainly for off line AC-DC power supply with input ranges from 85V-305VAC.
Hi Jon,
Thank You
Martok
