LNK306 no-isolated oscilloscope safety
Posted by: heli on
Is it safe to connect a oscilloscope to output of a working LNK306 board?
What about to connect a PC USB to a board powered by LNK306?
If not, what is the best way to do so? Add an optical coupler?
Submitted by PI-Jedidiah on 10/18/2017
Hi Heli,
Yes, it's safe to connect oscilloscope to a working LNK306 board.
With regards to PC USB connecting to LNK306 board, do you mean that the USB port coming from the PC will be directly connected to LNK306 board? The output of LNK306 board (those with design of 5V) has same characteristic with USB port of the PC so it can't be connected together.
Jedidiah
Submitted by heli on 10/18/2017
Can I use two LNK306 on same board, share same components, to get higher current output?
