Exposed thermal pad connection
Posted by: mquinlan on
Do I connect the exposed thermal pad on the TOP264KG regulator IC to ground or do I leave it unconnected? Its not clear on the data sheet.
Submitted by PI-PIke on 10/05/2017
Hi mquinlan,
The exposed thermal pad of TOP264KG is for heat sinking, if your IC is too hot you should attached it to a heat sink. If the temperature of the IC is good, it is alright to leave it unconnected.
PI-Pike
Submitted by kurniadi on 10/10/2017
hI mquinlan
you can found in the datasheet the Exposed pad has internally connection to SOURCE Pin (you can test it ), so i recommend : connecting the Exposed pad to SOURCE pin, it mean you make the pad on the PCB for it, so the PCB will help to dissipate the heat
