DPA425GN Problem
Posted by: ssshamil on
I am using various types of PI products like TOP253, TNY280. Now i made a design with DPA425GN. But not works properly. 5V output no load operation has 1.3V ripple voltage. And when i connect 100mA load, voltage dropping down to zero. When i analyze 5V output voltage on osilloscope, switching period looks 100ms. I attached PI expert file. I controlled all the components, transformer inductance, everything looks fine. Input voltage 30VDC. What am i missing.
Best regards.
TRC-R4-24V.uds (945 KB)
Submitted by ssshamil on 12/06/2017
Best regards.
Submitted by ssshamil on 12/15/2017
Any PI Forum Expert can answer this topic???
Submitted by PI-DATA on 01/03/2018
Can you send your circuit in image format.
Can't open the file that you have attached.
Regards.
Submitted by ssshamil on 01/03/2018
Hi;
Image file attached. If you need, i can share more details.
Hi ssshamil,
Your circuit seems ok.
You may want to visit our online design guideline on the link below to check for the component values(TRF, etc)
Hi ssshamil,
With the symptoms you have (5V output no load operation has 1.3V ripple voltage. And when i connect 100mA load, voltage dropping down to zero.) Kindly check properly on the start and finish of each winding. Be mindful of the termination of the start and finish of each winding of your transformer as indicated on your schematic diagram.
Hi;
Thanks for your support. I checked windings of transformer before, everything looks good. But i will recheck them today.
