440v 3 phase multi stage output power supply deesign
Posted by: mohan.n2293@gm… on
Hi Pi,
Myself mohan,for our application we need a power supply with 3 phase 440V input and 5V(10A),4V(2A),5(1A) Multi stage outputs.
Please reply me with a specified design.
Submitted by mohan.n2293@gm… on 09/14/2017
Hi Guys ,
Replay please
Submitted by PI-Mallora on 09/20/2017
Hi Mohan,
Thank you for your interest of using Power Integrations part.
Regarding your request, we don't have existing design to provide your required specification but we have tools for you to work on. See below link and try to input your requirements and it will provide you all the critical design materials from schematic, BOM and transformer construction. You input voltage is quite high for most of our parts. I'm thinking of Innoswitch2-EP which have 900V Mosfet version but your power requirement is high for this. See below link of our PIExpert Online tools. I'll get back to you if I had a better solution for your requirement. Thanks.
You just need to create your account. This will be helpful on all your future Power Supply design needs.
https://piexpertonline.power.com/
Submitted by PI-Mallora on 09/29/2017
Hi Mohan,
For higher input voltage specs beyond 400Vac, you can use StackFET design for Topswitch controller. Topswitch can provide your needed output power with multiple output. See below link for your reference design. Thank you. Hopefully it helps.
https://ac-dc.power.com/sites/default/files/PDFFiles/der105.pdf
