short circuit protection is not working
Posted by: signtronics on
I have designed a SMPS of universal input and 12V5A output using TOP249 YN.
The problem while testing is, When I apply AC voltage through VARIAC, Up to 120VAC
the short circuit protection works fine, but when I increases the VAC, then for short circuit
test IC burns out.
What is the problem,
Please Help
Submitted by signtronics on 07/07/2016
Please help, I have tried with different design of transformer, but still
getting same problem.
Please help
Submitted by PI-Neela on 07/12/2016
please share with us your system schematic and PIXL design. Also, what is the short circuit test IC you refer to?
Submitted by signtronics on 07/12/2016
I have added additional current limit circuit, as shown in schematic. Does inductance of transformer
has any effect on short circuit protection?
New Doc 35.pdf (327.53 KB) 327.53 KB
Submitted by PI-Neela on 07/18/2016
I assume you blow up TOP IC or your external short circuit protection IC?
one possibility is that your transformer is saturated under higher bus voltage and current increases dramatically during on time. You can probe the primary current with graduatlly increased Vac.
Submitted by signtronics on 07/18/2016
Yes sir, TOP IC blows up. I have tried different inductance values of primary winding to avoide transformer
saturation. I have also tried various turns ratios including the one which is given by PI Expert. I have also
tried removing external short circuit components. Still same happens. Please find attached PCB layout.
PCB Layout.png (100.4 KB) 100.4 KB
Submitted by PI-Neela on 07/19/2016
did you share with the PIXL file, that will help us to understand the design.
Submitted by PI-Neela on 07/27/2016
when I open your PIXL file, it is not readable. maybe you can convert it into PDF?
Please capture the primary waveform with lower Vac where you mentioned is not blow up, and around the boundary where blow up start to happen. Also monitor the wavefrom at the blow up event. That helps to dignose.
