load regulation on multi output supply with LNK6663
Hallo, we are designing a AC/DC-Converter with 85...265VAC input and multi supply outputs (5V/0.3A, 15V/0.2A; 5V/0.7A).
The max. total Power is 9W and we use a LNK6663K. The converter works in no load condition and in full load
condition. But if the 15V load is in no load condition, while one or both 5V loads are in full load the converter dosn´t
work.
Can you help us?
Michael
That means that the converter tries to start up but it goes in a fault mode after some cycles and treies to resatert after delay time.
Michael
Since this is multiple output power supply, Loading one output while the other output unloded completely can make the output voltage go out of regulation limits on the unloded windings.
I would need you to probe Voltage waveform on bias winding and bias winding output voltage inorder to see whats going on.
PI-NANO
Hi PI-NANO,
I made some measurements with the oscilloscope (s. attachment). It seems as that your assumtion is right.
How can I solve the problem? Is it possible to use a preload?
Is it possible to solve the problem with a other conversion IC family?
Our problem is that the descriped scenario is a possible scenario in our application.
A other problem in the application is, that the loads in the 5V supplies could be very
different. One supply powers a control panel with a TFT. The load varies strongly by
the backligth of the TFT (on/ off) while the other 5V&15V are in standby. The 15V supply is only used if the power MOSFETs
of a ultrasonic genarator are working (gate driver supply)
Michael.
| Attachment | サイズ |
| Waveforms (556.98 KB) | 556.98 KB |
Can you try adding some preload on the 15V output and see what happens?
PI-NANO
Can you please describe the problem?
What do you mean by the coverter doesn't work? Do you men poor load regulation?
PI-NANO
