LCS708HG problem
Posted by: mark0204 on
hi all
I have made a dc/dc converter with the lcs708(input dc 380v,output dc 130V/3A). All the design parameters
is according to the PI Expert to calculate . Now i  have forbidden the ov/uv pin,then change the input constant
voltage(B+/B- pin).My question is the transformer whether need make air gap? I test the HB pin waveform ,i
think it is be out of shape ,but i dont know the reason.
Submitted by PI-Neela on 03/21/2016
Your HB waveform has big ripple during turn on. For debug purpose, you can use the normal UV/OV resistor chain as recommended from PIXL. If waveform lools normal, then do addtional modification.
hi neela
Thanks for you suggestion. I have find the HB waveform problem, but i dont know the reason.  As you said
when use  the normal OV/UV resistor chain asrecommended ,the B+/B- voltage is cannot chang,according
to the file(hiperlcs_family_datasheetCN.pdf) the OV/UV pin is can forbiden.
Submitted by PI-Neela on 04/19/2016
I assume 1 waveform is HB waevform, what is the other waveform in your attchement? could you share with us your PIXL and schematic for debugging?
