Design of Telecom power supply -48Vdc
Posted by: vmholla on
Sir,
This query may look little silly, however I wanted some clarification. One of my customer has a requirement of -48Vdc Telecom power supply with multiple DC outputs. How should we design a -48V input power supply? Is it acceptable if we design a power supply with +48V and 0V input and during wiring the input +48V terminal would be grounded and 0V terminal would be the input?? Is this how it has to be wired?? Please find the normal DC-DC converter design which I am planning to use. Please comment.
regards,
mahesh holla v
Submitted by vmholla on 11/28/2016
Please clarify my query. It is little urgent and I need to process the transformer design for production.
regards,
mahesh
Submitted by PI-Mallora on 11/28/2016
Hi Mamesh,
Regarding your question, that is actually how it works connecting the 48V load to RTN(0V) of the power supply then 0V of the load to the 48V of the power supply to have -48V input to your load.  Have the feedback connected to your 48V output if you want to have better regulation for your 48V.  Thanks.
Many thanks for your reply.
I didn't get your last sentence!!!,
"Have the feedback connected to your 48V output if you want to have better regulation for your 48V".
-48Vdc would be the input to the power supply with multiple DC outputs such as 5Vdc, ± 12Vdc.
Do you have any reference design circuit which shows the feedback connection??? or you can just scribble on the schematic that I have sent and resend??
Thanks for the wonderful support from PI.
regards,
Hi Mamesh,
What I mean is from the same schematic that you have, convert the 5V output to 48V so that your feedback is on the 48V output for better regulation of your -48V output.  However if you are not much concern with the regulation of your -48V, you can just convert the -12V output to -48V with the feedback loop at your 5V output.
I am not getting why i should convert the 5V output to 48V.
Please note that the input to this power supply (DC-DC converter ) would be typically -48Vdc, from a battery, but I have designed for the range 36V to 72Vdc.
Referring to the design which i have sent earlier, i require 5Vdc, +12V and -12V output which goes to my other circuitry.
Hope I have made clear about my requirement.  I have already got the transformer details for my requirement and the schematic i have sent to you.
regards,
mahesh
Hi mamesh,
Sorry for confusion.  I thought you are designing a power supply that needs -48V output that is usually used in telecoms.  Again sorry for that.
Yes your idea is correct how you connect the input of the DC-DC power supply from the battery.  Your design is good to go for your multiple output requirement.  Thanks you.
