144W Flyback transformer design
Posted by: kmohan.np on
We have designed 144W AC-DC flyback converter using TOP271EG, EER35 Core transformer and the design spread sheet is attached to the post for your kind information.
Gap length, lg should be 0.66mm and we select no. of primary layer, L=1. Since minimizing the no. of primary layers reduces the primary winding capacitance and leakage inductance. Hence please check the design and validate, since in all the design examples L should be more than 1.
Thanks and regards,
Mohan Kumar K
Submitted by kmohan.np on 11/21/2016
Hi PI,
Please give your comments on transformer Primary layer selection.
Thanks and regards,
Mohan Kumar K
Submitted by PI-Picard on 11/25/2016
Hi Mohan,
Thank you for considering our TopSwitch-JX Family in your power supply design.
I checked the PIXls spreadsheet that you attached and your design looks ok. Noted that there were no errors or warnings.
This suggests that your design is acceptable.
PI-Picard
Submitted by kmohan.np on 11/25/2016
Hi Picard,
Ok.
Thank you and Good day.
Mohan
