TOP264 flyback with lithium battery
Posted by: Eugeni
I'm designing a 35 W flyback that the input voltages comes from a lithium battery( 24V 6600mAh) .
Could I use any of the TOP264 or similar family device?
Thanks in advance.
thanks a lot for your answer. DO you have any device that can i use with 24 vdc of input? thanks
Yes, you can use TOPSwitch-HX for 24V DC Input.Please go through our TOPSWITCH-HX Datasheet.
Thanks for Posting your question into forum. As per the datasheet for all of our parts, they should require minimum input of 50V DC Voltage.How ever we have a one part DPA Switch which has to be minimum input of 36V DC.
PI-KSAN
