External MOSFET Blown in StackFET configuartion
Posted by: vignesh_viki on
HI......
I design a smps working on 85AC to 300VAC...
I extend input range into 85AC to 500AC using stackFET...
It working fine on gradually inceasing the input voltage upto 500VAC.
But suddenly applying 500VAC the External MOSFET(IRFBC40), 3X P6KE180A, 10 ohms resistor,15V Zener burned.
 Please answer as early as possible..........
Submitted by PI-NANO on 09/21/2015
Could you please send the schematic, PCB Layout and and transformer document?
PI-NANO
Submitted by vignesh_viki on 09/24/2015
i attatch the sch and transformer constrcution file for your refference... please reply as early as possible
TOP268_2 transformer.pdf (76.13 KB) 76.13 KB
stack fet 2.JPG (50.26 KB) 50.26 KB
Submitted by PI-NANO on 10/01/2015
What is output power that the power supply is designed for?
Can you probe Vgs and Vds at turn on and in steady state?
How did you choose resistors R6, R8, R16 and zeners D9, D10, D11?
PI-NANO
Submitted by viki_csk on 10/26/2015
Based on DI-124 I choose resistors R6, R8, R16 and zeners D9, D10, D11 values.
Submitted by PI-NANO on 10/28/2015
PI-NANO
Submitted by viki_csk on 10/28/2015
This is 50W design.
I dont have a high voltage probe to measure VDS
Submitted by PI-NANO on 10/30/2015
StackFET designs are recommended only for very low power applications. DI-124 was designed for a 3W application.
PI-NANO
Submitted by PI-NANO on 11/24/2015
Still this design is very high power. However you can try the following things on your design and see if the problem gets resolved.
1. Please try ultrafast diode on D6 (You could use UF4007)
2. Short R7 or replace with 0 Ohms.
3. Move R16 in series with D9 and connect D12 cathde and M1 gate between R8 and R16
PI-NANO
