Trouble with TOP259YN
Posted by: jean.romain.durand
I have some trouble with TOP259YN.
Few IC have the G pin and the S pin with high Z when I connect an ohm meter.
Should It have a low Z betwin this two pin?
Jean-Romain
thank you for your quick reply!
So, If I measure a hight impedance, the chip should be damaged?
Jean-Romain
please see figure 3d of the below link
http://www.powerint.com/sites/default/files/product-docs/tophx_family_datasheet.pdf
you will see a short from signal ground to source
If you are not measuring a short, it means your part in damaged
You should measure low impedance because the pins are internally connected. The reason to have them separated outside the chip is to have a zero reference inside the chip. In other wors, to avoide the voltage drop of the SOURCE leg due to its ohmic resistance
