TOP249YN makes so much noise
Posted by: nhuan on
Hi everyone !
I have used PI Expert software to design 2 power supplies 12V - 5A use TOP249YN.
I measured their output voltages with the output current 500mA.
Submitted by nhuan on 02/18/2014
And the other is this
I use my receiver with the 1st supply, it 's good, but the 2nd is too bad.
So, what cause the different between them?
Submitted by VCastrellon on 02/19/2014
When using the oscilloscope to measure output voltage, the measurements need to be done as indicated in section 11.5 of the below link. I think after using this method you would not see what you are looking now.
 http://www.powerint.com/sites/default/files/PDFFiles/der105.pdf
Submitted by nhuan on 02/19/2014
Thank you very much !
you are welcome
