Output oscillations on LNK302 in low-side buck-boost with optocoupler feedback
Posted by: jim.patterson@… on
I am using LNK302D in low-side buck-boost configuration with optocoupler feedback.  I took the design from the  circuit on p.3 of AN-37.  My output is +5V with respect to +Vin.
 My diode is an ES1J (35ns trr),  optocoupler is TCMT1107.  The inductor is a 1200 uH Coilcraft RFB0807-122, as recommended in the application report.  The output capacitor is a 30uF MLCC.
I have sawtooth oscillations that are >400mV peak-to-peak at ~1KHz with no load.  When the load is connected (~20mA at 5VDC) is connected, the amplitude drops slightly to ~300mV and the frequency increases to ~7KHz.
I really need to eliminate the oscillation, or at least knock the amplitude down to about 1/2 what it is.  Any suggestions?
I can provide schematic, layout, and output waveforms if necessary .
Submitted by PI-Sarek on 11/05/2014
Yes, please provide a copy of your schematic and layout and also waveforms so we can support you better.
Regards PI-Sarek
Submitted by jim.patterson@… on 11/06/2014
Hi, please see the pdf file:
p1 - schematic
p2 - silkscreen
p3 - top
p4 - bottom
p5 - loaded output
p6 - unloaded output
The noise amplitude I provided initially is wrong, I was working from memory rather than from the scope captures.  Unloaded noise is ~300mV peak-peak, loaded is ~400mV
Submitted by PI-Sarek on 11/14/2014
I do not see any attachments with your message. will you please upload again?
