LED LAMP DESIGNING USING LYT006P
Sir I'm Akhil from INDIA. we are LED LAMP MANUFACTURING UNIT using LYT0006P IC. its our 1st product sir. hopefully it will be a great success. sir i have few doubts regarding the specification.
1. please suggest an led manufacturer suitable for 110ma 3v
2. since the circuit uses a customized transformer we couldn't find a suitable for the circuit. wolud you please provide an alternate for the same thank you sir
Sir we have choosen NIchia'S NFSW157A LED for our lamp. will it be a good choice sir? please do check it and reply sir.one more doubt sir... can i use Inductor in place of transformer for our product economically? then please mention the part number/manufacturer /specification. your valuable guidance is our asset. Thanking you sir
The LED is good, make sure you have a good design of heatsink to dissipate the heat.
Yes we have used standards inductor in some design. Please see attached:
http://www.powerint.com/sites/default/files/PDFFiles/rdr378.pdf
http://www.powerint.com/sites/default/files/PDFFiles/der384.pdf
http://www.powerint.com/sites/default/files/PDFFiles/der387.pdf
Follow the spreadsheet to calculate for the correct inductance. Send it to us if you have some doubt in your calculation.
Again, make sure you have a good way to dissipate the heat of the LED. Based on our customer support experience, normally the mechanical design for LED heatsink is not sufficient. Make sure to conduct thermal test on your final assembly to determine the ambient operating temperature of the LED driver.
PI-Jono
sir i have gone throuth the attached PDF for 388, 384, 387,. its good to see none of the circuits contains Transformer. Also the inductor value is been specified.
sir can you help by providing the INDCUTOR VALUE and specification for LYT0006.
Thanks for your systematic valuable guidance. No words to tell you are an absolute Guide to follow.
Hi Akhil,
110mA 3V, you can approach CREE for LED samples.
http://www.cree.com/LED-Components-and-Modules/Products/XLamp/Discrete-Directional/XLamp-MLB
Please contact Bourns, Renco, TDK, Pulse Eng, etc. for magnetic support. You can ask them for custom designs but try to use standard inductor first for cost effective design.
Congratulations for your first product! Feel free to contact us or our sales department in your area.
INDIA (New Delhi)
#45, Top Floor
Okhla Industrial Area, Phase – III
New Delhi, India
Pin – 110020
Tel: +91-11-4055-2351/53
Email: indiasales@powerint.com
PI-Jono
