DI 152
Posted by: BDD
Hi All
Need some info on design Idea 152
I need a wide input 18VDC-265VAC psu that can kick out 24VDC 2.5Watt. 5Volt is also OK.
Will this design idea work? and what is the size of thw windings about?
Kind regards
Ben
Basically
Ineed to design a supply that can take 20VDC to 265VAC. and need to put out 24V 0.1mA
If the input is below 25V then the output can track the input. not problem
Any suggestions
Is the concern the output voltage is higher than the input voltage?
It is a flyback, the output voltage can be designed to be higher than input voltage.
In the DI 152, the output voltage is 5 V/0.6A.
If I understand well, you want to design a power upply with 24Vdc/2.5W, correct? The idea is the same, it should be okay to work for a 24Vdc output as well.
