TOP 243Y Explosion failure
Posted by: xumyryvyz on
Hi All,
I am using top switch 243Y Design for low power aux. supply. +15VDC in a ac/dc power supply
with power factor. After a period of time 3-5 Months complaint is top switch blowing apart.
Can you see anything wrong with the design. Here is my schematic drawing.
Notes: input a clean 390VDC Boost voltage . Output +15VDC@approx.12W.
Thank You.
Del
CCI Power Supplies, LLC
PH: 407-339-2121
Submitted by PI-Terry on 09/27/2013
Hi:
I did take a look of your schematic, before going into detail analysis, would you please let me know whether you use a zener or TVS in your claping circuit?The schematic is not clearly showed, I can not tell the reference of this part, but I mean it is the 200V zener (or TVS) for 503?
Hi Terry,
It is a 200V TVS for 503 claping circuit.
Thank You,
Del                      Hope to here from you.
Submitted by PI-Terry on 10/15/2013
Hi, thanks for the information.
I just notice the 22kohm resistor in the clamping circuit is a little lower than normal, with clamping voltasge equal to 200V, will get the power dissipation of this resistor to be 1. 82W which is close to the rating 2W. Did you see this resistor getting black in the field?
Did you also notice some abnormal components on the failed board? Did you test the drain votlage during the startup at highest input voltage and maximum load, what is the margin do you get?
Submitted by xumyryvyz on 10/16/2013
Hi Terry,
Your right the Axial leaded 22K Resistor body temperature max. input voltage--max. load no air 103c@27c ambieant.
The unit does have air flow. Never saw the resistor changing colors. No other components failed on  board except
top switch. Attachments are turn on picture and continuous on. Drain,source voltage. Conditions 264vac ,Max. load.
Note: I am using a boost front end pfc circuit 390vdc +/-5V. Top switch input voltage same. Another attachment is
the transformer design if you could please take a look . Pins 1-2 and 9-10 not used.
Thank You,
Del
Submitted by PI-Terry on 10/16/2013
Thanks for the file.
The power supply only failed after 3-5 months' operation. That is a indicator that some components may be damaged firstly that causes the TOP switch eventurally failed. The failure may relate to the application condition (temperature, humility, ect.) in the field too, this may cause the insulation failure or transformer satuation which may cause the failure of the topswitch too. Do you have any clue that this power supply only fail at some specific applition?
The other thing I can think is the PFC circuit, are you sure the output voltage of the PFC is guaranteed to be inside of 390Vdc?
What is the peak flux density of the transformer you designed?
Hi Terry,
When the units are sent back from the field for repair 4 out of 10 are the top switch only. Replaced  top
switch and recycled through test, burn-in and final test unit ok. In some locations the temp. of top switch my run
case 100c continuous.  The same top switch is used on other projects. I will check on the return rate failure of the top switch only. The pfc is guaranteed  to be within limits of  390vdc+/5V. Designed Peak flux density  (<2000).
Thank You, Del
Submitted by xumyryvyz on 10/28/2013
Hi Terry,
Waiting for reply. Sent oct.18-2013.
Submitted by PI-Terry on 10/28/2013
Unfortunately I do not think we can come to a clear conclusion of the failure reason at this point with the limited information. I will suggest you to contact with PI quality department through PI FAEs to help you to do more close analysis. You may need to send the failure parts and board for analysis.
